Thread: Clipping |
New member Username: Spads8
Post Number: 2 Registered: Apr-08
| Posted on Saturday, April 26, 2008 - 02:05 am: |
is it possible for my subs to clip from an mtx tc2002 amp |
Silver Member Username: Imalik
15 SI Mag9.1=Boom,
New Jersey
Jerzee Playa
Post Number: 583 Registered: May-06
| Posted on Saturday, April 26, 2008 - 07:12 am: |
Yes, If the gains are not properly set, the amp will clip |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1490 Registered: May-07
| Posted on Saturday, April 26, 2008 - 11:26 am: |
Any amp can clip. Not to mention your HU can clip too. |
Bronze Member Username: Peakohm
Post Number: 20 Registered: Apr-08
| Posted on Saturday, April 26, 2008 - 11:29 am: |
Yup, the amp can and will clip if the gains arent properly set. http://www.subwoofertools.com/forum/setgain.asp that might be of some help. |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 12119 Registered: Dec-03
| Posted on Wednesday, April 30, 2008 - 01:34 am: |
not possible, because subs don't clip. amplifiers clip. however, your amp can and will clip as mentioned above, if the gains are set too high, or you lack sufficient current to sustain proper voltage rails for the amplifier due to an insufficient charging system in the car. |
