Thread: Smoke Coming From Amp |
New member Username: Erik_hd315
Post Number: 1 Registered: Apr-08
| Posted on Friday, April 25, 2008 - 10:53 am: |
I have a massive audio p1500.1 running to an audioque hd315 at 1 ohm. I am running 4 gauge wire and have a brand new battery. I have had it for almost a year and have had no problem. Today while driving and Listening to my system like usual i smelt something like electrical smoke. I didn't notice anything at first because the sub had no difference in sound and the amp was still running fine. I only realized there was something wrong form the smell, then i noticed some smoke coming from the amp. Anyone have any idea what is wrong with the amp? I thought i might have fried it but wouldn't the amp not work properly? |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 7974 Registered: Jul-06
| Posted on Friday, April 25, 2008 - 01:54 pm: |
Please disconnect the amplifier and reduce the risk of a potential fire. Make sure to go over all the wiring that you have. Lastly, make sure you're running the amp at proper ohm loads and you have the gain properly set for the signal you're running. It could just be a crappy amplifier. |
Gold Member Username: 04redmach1
Lagrange,
GA
Post Number: 1823 Registered: Mar-06
| Posted on Friday, April 25, 2008 - 03:40 pm: |
I suggest, go ahead and use that 2 year warranty. Something will go very soon in that amp. I no longr cary Massive for the fact the amps are unpredictable and fry out of nowhere. Kevin PS: Not too mention the 12 waranty claims I had in a month. |
Post Number: 2 Registered: Apr-08
| Posted on Friday, April 25, 2008 - 04:21 pm: |
It says on the site that the 2 year warranty only is valid if you have the amp installed by a masive audio retailer. I ordered mine over the internet so how does the warranty work for me? |
Lagrange,
GA
Post Number: 1824 Registered: Mar-06
| Posted on Friday, April 25, 2008 - 04:39 pm: |
Where from the internet? My customer gets warranty either way. But if you got it off ebay, you are screwed. Kevin |
Post Number: 3 Registered: Apr-08
| Posted on Saturday, April 26, 2008 - 12:24 pm: |
I got it from www.hifisoundconnection.com almost a year ago. Also i don't think i kept the bill or anything. |
