Thread: Ok to position my subwoofer like this? |
New member Username: Pb2j
Post Number: 1 Registered: Apr-08
| Posted on Friday, April 25, 2008 - 10:22 am: |
I have a subwoofer in an enclosure in my trunk and I noticed that I maybe getting better sound, vibration if I point it straight down at the trunk. The enclosure makes it so that it is touching the ground not the sub itself. But I'm not sure if sound quality is improved. Does this sound right and if so, is it safe to leave it like this? |
Gold Member Username: Insearchofbass
Post Number: 9056 Registered: Jun-04
| Posted on Friday, April 25, 2008 - 10:28 am: |
so your saying your down firing it? |
Post Number: 2 Registered: Apr-08
| Posted on Friday, April 25, 2008 - 10:32 am: |
Uhh maybe? That sounds like it could be the term to describe it. I don't know much about car audio, I just came here today to get my question answered. Sry for being a noob. |
Post Number: 9058 Registered: Jun-04
| Posted on Friday, April 25, 2008 - 10:41 am: |
well if your down firing just make sure the sub has enough clearance for the excursion (amount the sub moves) so that it doesnt hit anything...as far as what postion sounds better your just going to have to try them out and see what sounds best to you |
Post Number: 3 Registered: Apr-08
| Posted on Friday, April 25, 2008 - 10:44 am: |
thanks man, just what I needed to know |
Post Number: 9061 Registered: Jun-04
| Posted on Friday, April 25, 2008 - 10:46 am: |
yw |
