Thread: Noobie question |
New member Username: 334ballin
Post Number: 7 Registered: Apr-08
| Posted on Thursday, April 24, 2008 - 04:15 pm: |
well i decided to hook my door speakers to my 400w 2/3/4 channel amp but once i did this there was no music no nothing but i kno for a fact the speakers wrk and the amp was im pretty sure all hooked up right.. but iono wats wrong and i need yalls help.. so basically i need to kno the correct way to hoook an amp to speakers and have music come out of them.. |
Bronze Member Username: 4realadeala
Tampa,
Florida
Post Number: 24 Registered: Mar-08
| Posted on Thursday, May 01, 2008 - 04:25 pm: |
please explain how you hooked it up. |
Gold Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 1741 Registered: Mar-05
| Posted on Saturday, May 03, 2008 - 10:54 am: |
Well with a 4 channel amp and 4 speakers its fairly straightforward. Run power wire from the battery, run a good ground from the amp to the chassis of the vehicle. You need 2 pairs of RCA's and run them from the back of the head unit to the correct inputs on the amp. Then get some 12g speaker wire and run positive and negative wires from the amp to the speaker and repeat. Hope this helps. |
Post Number: 8 Registered: Apr-08
| Posted on Monday, May 05, 2008 - 03:20 pm: |
well i only have one pair of RCA cables running into my radio into the holes labled front speakers then to the amp on like side A or sotmhing like that.. do i need to get another cord? |
