Home > Message Board > Car Audio > Security Systems > Clifford 650 mad fault?
Author Thread: Clifford 650 mad fault?
Username: Skyliner1
Uk
hi all, i hope someone can help me as i'm pulling my hair out on this one
i have a clifford concept650 fitted to my 96 skyline and am having a problem
when i set the alarm, i get two blips and two flashes, all ok there, then about 10 secs later i get four blips and four flashes, then the alarm goes off.
when i unset the alarm and turn ignition on. the led flashes 3 times telling me that its a tilt/motion sensor that triggered the alarm, and i dont have one fitted!!!!!!!
please can someone help as its annoying me and the neighbours
this has ben happenning for some time now, after the battery had gone flat and was jumpstarted from a power pack by the recovery service
cheers
simon
Relevant Product Info
Username: Skyliner1
Uk
aaarrrgggghhhhhh anyone??????
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Security Systems > Clifford 650 mad fault? [ « Previous ] [ Next » ]
