Thread: New subs need amp |
Bronze Member Username: Joebud91
Post Number: 15 Registered: Oct-07
| Posted on Thursday, April 24, 2008 - 07:14 am: |
i have 2 kenwood kfc-w3011's with 4 ohm's, 400 watt rms, and 1200 peak power....what amp should i use and should it be multichannel, mono, or 2 channel thanx |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5302 Registered: Dec-05
| Posted on Thursday, April 24, 2008 - 08:12 pm: |
you should buy a mono amp class D. Your subs are dual voice coil or single? Tell us your budget |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 910 Registered: Jun-06
| Posted on Thursday, April 24, 2008 - 10:29 pm: |
If im not mistaken, I believe that sub is only available in SVC 4ohm. |
Spencerport,
NY
Post Number: 911 Registered: Jun-06
| Posted on Thursday, April 24, 2008 - 10:31 pm: |
This amp would do nicely with those subs: http://www.sonicelectronix.com/item_6522_Hifonics+BXi+1206D.html It's a little over rated (around 20%), but it should still make a nice match up. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1538 Registered: Mar-04
| Posted on Thursday, April 24, 2008 - 11:22 pm: |
something around 800w at 2 ohms this would work well -- http://sonicelectronix.com/item_9795_Phoenix+Gold+Ryval+V8001.html |
