Thread: Dd audio...need help....... |
New member Username: Gothicstretch
Ohio
Post Number: 2 Registered: Apr-08
| Posted on Thursday, April 24, 2008 - 12:58 am: |
im looking to buy some dd subs and amp but cant find a dealer anywhere i live....is there a site online i can buy them at? ive tried searching but cant find anything...... or any advice on some other subs and amp combo to go with to hit some HIGH db numbers....i was looking at purchasing the 12"pioneer premier ts-w3001d4 with some power acoustic 4000watt mono d block amps and running the at 2 homs....looking to get into some spl comps and just not sure what to really go with...any advice and help would be great |
Gold Member Username: Joebruce
Mach5Audio M...
Post Number: 1996 Registered: May-04
| Posted on Thursday, April 24, 2008 - 01:07 am: |
email DD theres a link on their site |
Platinum Member Username: Rovin
1 15 = 149.1DBs Trinidad & T...
Post Number: 13620 Registered: Jul-05
| Posted on Thursday, April 24, 2008 - 01:09 am: |
so u already checked http://www.ddaudio.com/dd/default.asp ??? check out the other brands here http://forum.ecoustics.com/bbs/messages/4/472940.html ....... |
Ohio
Post Number: 3 Registered: Apr-08
| Posted on Thursday, April 24, 2008 - 01:40 am: |
i went to there site and found that there is only 1 dealer with in 200 miles of me and they want to charge me over 2000 for a dd500 series i know dd is expensive but they not that expensive. especially ffor the 500 series. so i was wondering if there was a site that sels them online. |
Mach5Audio M...
Post Number: 1997 Registered: May-04
| Posted on Thursday, April 24, 2008 - 01:46 am: |
You can order them online through DD.com Email them for prices and payment info |
Ohio
Post Number: 4 Registered: Apr-08
| Posted on Thursday, April 24, 2008 - 02:09 am: |
i emailed them twice and all i keep getting is a dealer find automated type of message lol if there isnt any other site to order from what are your takes on the pioneers and amp im also looking at? |
Gold Member Username: Redliner
Wilmington,
Ma
Post Number: 4322 Registered: Jun-05
| Posted on Thursday, April 24, 2008 - 09:37 am: |
call them with the number on the site ask if you can order direct from them. Cause theres no dealer around you. They should have no problem with it since they use to do it all the time. Also why dont you find a used one online for cheaper |
Silver Member Username: Kingtutus
Lincoln,
Nebraska
U.s.a
Post Number: 254 Registered: Dec-07
| Posted on Thursday, April 24, 2008 - 10:06 am: |
go with rd instead of dd |
Wilmington,
Ma
Post Number: 4324 Registered: Jun-05
| Posted on Thursday, April 24, 2008 - 11:21 am: |
why please tell me why |
Ohio
Post Number: 5 Registered: Apr-08
| Posted on Thursday, April 24, 2008 - 11:57 am: |
where could i go online to buy them used or what not? |
Wilmington,
Ma
Post Number: 4328 Registered: Jun-05
| Posted on Thursday, April 24, 2008 - 12:04 pm: |
soundpressure.com will have the most |
Ohio
Post Number: 7 Registered: Apr-08
| Posted on Thursday, April 24, 2008 - 12:50 pm: |
thanx ill check that out real quick |
Gold Member Username: Jkidder
Worlds gunna end,
In
2012
Post Number: 3488 Registered: Nov-05
| Posted on Thursday, April 24, 2008 - 03:35 pm: |
timmy, stfu chris, visit soundpressure or ca.co/forums and got to the classified sections. they always have people selling dd. id bomb the shop that told you 2000 dollars for a dd 500 series. literally, id send a bomb to the shop. the cisco kid |
Diamond Member Username: Bestmankind
Los Angeles,
CA
Post Number: 20523 Registered: Oct-05
| Posted on Thursday, April 24, 2008 - 06:38 pm: |
that is brutal cisco kid. |
Ohio
Post Number: 8 Registered: Apr-08
| Posted on Thursday, April 24, 2008 - 07:43 pm: |
thanx cisco. anyone know how much the Z series goes for on the 12s? |
Silver Member Username: Goodie_goop
Mid town,
Texas
U.S.
Post Number: 870 Registered: Oct-06
| Posted on Thursday, April 24, 2008 - 08:26 pm: |
"anyone know how much the Z series goes for on the 12s?" more then you are willing to pay |
Gold Member Username: Zacdavis
Beloit,
Wi
Post Number: 1640 Registered: Dec-03
| Posted on Thursday, April 24, 2008 - 08:33 pm: |
http://www.caraudio.com/forum/showthread.php?p=4454737#post4454737 |
Gold Member Username: Dakangofkrunk16
Boca Raton,
Florida
Post Number: 1595 Registered: May-07
| Posted on Thursday, April 24, 2008 - 10:58 pm: |
3000 |
