Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > The worlds biggest noob ?
Author Thread: The worlds biggest noob ?
Username: Deadrabit
Post Number: 359
my sub has terminals on 2 sides. so it has 2 neg and 2 pos places to put the wire.
i have it wired to my amp at 1 ohm and the wire just goes to a pos and a neg on the sub.
should i have wire going to neg to neg and pos to pos on the sub too?
Username: Rovin
1 15 = 149.1DBs
Trinidad & T...
Post Number: 13618
ur sub is dual 2ohms ?
if yes & u want it @ 1ohm then connect the 2+ together & same with the 2_ & then connect to ur amp ....
Username: Deadrabit
Post Number: 360
yes its dual ohms.... so r u telling me that this whole time i have had this set up wrong?!
Username: Rovin
1 15 = 149.1DBs
Trinidad & T...
Post Number: 13619
well basically this is what u do :
Username: Mesodumm
Tri-City, Az
Usa
Post Number: 464
How do you know it dual 2 ohm? it could be dual 4 ohm? Just because he thinks it's wired at 1 ohm doesn't mean it is! Did you use a ohm meter?? to see what it is?? What is the model # of your sub??? That would make it a lot easier!! Thx p.s. i'm not trying to be dickish. It's late, I'm tired! sorry!
Username: Shortysetnies
Rock Vegas, NC
US
Post Number: 2466
if that sub is a DVC 2 or 4 ohm, wire it just like that pic rovin posted. If its a 4, the amp will see a 2 ohm load if its a 2, the amp will see 1 ohm
Username: Deadrabit
Post Number: 361
its an 18 inch BL.
2 ohm i am pretty sure.
it has to be 1 or 2 ohm.
how can i tell?
so what is mine wired to now????
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5543
do you only have 1 VC wired up?
Username: Deadrabit
Post Number: 362
i had only 1 VC wired up.
i got it togather right now.
i went from 142 to 145 db.
that was my problem the whole time!
Username: 4realadeala
Tampa, Florida
Post Number: 10
By chance, are you using a walmart Boom Stick to get your reading? I thought about getting one, but the damn thing was too expensive.
Username: Deadrabit
Post Number: 363
no i have not seen them.
i just go to th local car audio place down town. what they have is nothing fancy but it gives me number to go off of
Rock Vegas, NC
US
Post Number: 2470
the wal mart thing is sh!t. it is so off and varies from one day to another. no need to waste your money.
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2002
i have one of the boom sticks lol. it was like 10 bucks at the time so i picked one up lol they are very inaccurate thats forsure
Username: Rovin
1 15 = 149.1DBs
Trinidad & T...
Post Number: 13632
wow - 1 coil hooked up all the time ...thats like u had only 1 nut in ur sack working .....
Tampa, Florida
Post Number: 18
On a serious note, I believe that one teste is just filling space while the other one does all the work.
Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > The worlds biggest noob ? [ « Previous ] [ Next » ]
