Thread: Speaker help |
New member Username: 334ballin
Post Number: 2 Registered: Apr-08
| Posted on Wednesday, April 23, 2008 - 11:08 pm: |
i have two 6x9 speakers hooked to a 400watt 4 channel amp , but when i turn my music to the max its really not loud at all.. wat do i do w.out blowing the speakers..? |
Silver Member Username: Treez
Its not loud until it ...
Post Number: 333 Registered: Aug-06
| Posted on Wednesday, April 23, 2008 - 11:16 pm: |
1.Determine the impedance of the speakers and wire accordingly to the amp. 2.Ensure that your crossover is set to highpass or fullrange, whichever suits your listening needs. 3.Set the gains on the amp using a dimm at about 3/4 volume(never full volume). 4.Play properly recorded music...lol
Post Number: 3 Registered: Apr-08
| Posted on Wednesday, April 23, 2008 - 11:20 pm: |
haha thanks.. but wats a dimm? |
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
Post Number: 110 Registered: Mar-08
| Posted on Wednesday, April 23, 2008 - 11:35 pm: |
digital multimeter. a ohm meter in plain english. its also refered to as a volt meter. both can be set to do the same things just have different names/ |
Gold Member Username: •cam•
BC
Post Number: 2434 Registered: Nov-06
| Posted on Thursday, April 24, 2008 - 12:02 am: |
You should be a little more clear, oh guru Ware. ;) A multimeter can measure resistance and voltage. I think you might be a little confused though. There are devices that strictly measure voltage and others that strictly measure resistance. A multimeter is a multimeter. A volt meter is not. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5304 Registered: Dec-05
| Posted on Thursday, April 24, 2008 - 08:23 pm: |
multi= variety, a bunch, a group LOL! Start from there. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7434 Registered: Jul-06
| Posted on Saturday, April 26, 2008 - 12:03 pm: |
And amperage. Usually up to ~10 amps. |
