Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > MTX Subwoofer
Author Thread: MTX Subwoofer
Username: Jrome23
I am looking into buying a new subwoofer but I don't know what is good or not. The one that I am looking at is the MTX RTP212 package. (http://www.amazon.com/MTX-Subwoofer-Amplifier-Package-RTP212/dp/B000150L5I) Is this a decent sub for the price? My old one is an Audiobahn ATB8AT. I am looking to upgrade but don't want to spend too much money. This one sells for about $150. Thanks for any help!
Username: Surferdude9371
Im BTL Bumpin
Post Number: 848
whats your max buget, car, and how much room do you have? does your buget include only sub and amp or do you need a hu, wires, batts, ect
Username: Jrome23
I don't want to spend more than $250 for everything and room won't be a problem.
Username: Drant19
DUB-C, TX
Post Number: 821
either save up more or get a single sub
Im BTL Bumpin
Post Number: 849
everything meaning?
Username: Drant19
DUB-C, TX
Post Number: 823
everything meaning sub, amp, box..thats my guess. if hes looking at what that link is, hes not gonna need a HO alt or batts or anything like that.
Im BTL Bumpin
Post Number: 850
http://cgi.ebay.com/BRAND-NEW-KICKER-CVR15-COMP-VR-15-SUB-2-ohm-1000-W_W0QQitemZ 180234762225QQihZ008QQcategoryZ18804QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Hifonics-Brutus-BXi-1606D-Monoblock-D-Class-Amp_W0QQitemZ300 218782576QQihZ020QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
For your price this should be an ok match and make your own box. Although ill tell you what i tell everyone else I AM NO EXPERT so get more opinions
Im BTL Bumpin
Post Number: 851
although if you dont buy that exact amp at the link you might be able to find another 4 ohm stable amp cheaper
Username: Drant19
DUB-C, TX
Post Number: 826
that amp is wayyy too much for that sub! do not buy that combo. the sub is alright however i would try to get an Alpine type-r dual4ohm and try to find a refurbished kicker amp on ebay.
Im BTL Bumpin
Post Number: 852
how is that amp way too much for 100 bucks it does 550 rms at 4ohms
Username: Somedonniedude
Illinois
United States
Post Number: 1479
Get the dual 4 ohm version and run that amp @ 2 ohms, that will be plenty of power for that sub, with the headroom to add another one on in the future IMO.
Username: Joebruce
Mach5Audio M...
Post Number: 1994
I have a Mach5 Audio MAW for sale. Its prolly the best bang for your buck. Heres a link to their site.
http://mach5audio.com/zen/index.php?main_page=product_info&cPath=66&products_id= 204
$90 shipped
Username: •cam•
BC
Post Number: 2437
Definitely the best bang for your buck. I have a pair of the 12" MAWs and they're nuts for the money.
Username: Joebruce
Mach5Audio M...
Post Number: 1995
Indeed cam. I was very impressed at how the MAW sounds,killer sub for the money.
Username: Drant19
DUB-C, TX
Post Number: 828
MAW is the best deal.
Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > MTX Subwoofer [ « Previous ] [ Next » ]
