Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > Got a Question
Author Thread: Got a Question
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1589
Ok i know that Bass Booster up is bad, and loudness too... But what if u have an EQ on ur head unit like i got Highs Mids and Lows.... Could i turn the Lows up and not worry about messin my sht up????
Diamond Member
Los Angeles, CA
Post Number: 20487
bass boost and loudness isn't bad. but if you over do it on the bass boost, it can be. you just gotta know what you are doing.
its good to try out all possibilities to see what you like best. if that requires bass boost and loudness then be it. but if you set the gain correctly and find a nice curve on your eq, you really don't need bass boost and loudness.
Boca Raton, Florida
Post Number: 1590
I don't wanna use bass boost... so its ok to set my EQ low a lil bit up i already got the mid on like 2 and the high on 4 im thinking about putting low on like 2 or 3 ... ima leave bass boost and loudness off... I have experimented and so far have not heard any clipping...
Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > Got a Question [ « Previous ] [ Next » ]
