Thread: Why wont they hit!!!???? |
Bronze Member Username: Killacam
Post Number: 22 Registered: Apr-08
| Posted on Wednesday, April 23, 2008 - 10:44 am: |
I have two 12" alpine type s. 4 ohm. they are 300 watts rms. I have a V12 alpine amp, cant remember the exact model but I KNOW that it when bridged it is 300x2 watts rms at 4 ohms. It should be a perfect match. I turn my car on and turn it up and it just wont hit unless i turn the loud function on my deck on and or turn the bass on the deck up which makes the sound quality sh*tty and worries me about clipping and ruining my subs. I had 2 crappy 12" kenwoods before the alpines with a pyramid amp and they hit hard with no problem, but i think i had the bass boost up (before i knew about clipping). What could be the problem? the box? |
Diamond Member Username: Bestmankind
Los Angeles,
CA
Post Number: 20489 Registered: Oct-05
| Posted on Wednesday, April 23, 2008 - 11:57 am: |
where is your gain set at? |
Post Number: 23 Registered: Apr-08
| Posted on Wednesday, April 23, 2008 - 12:50 pm: |
i'll have to look at it but i know its pretty high. I set it to the manufactures suggestion. |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1141 Registered: May-07
| Posted on Wednesday, April 23, 2008 - 01:21 pm: |
since u know little about the gain let me take a stab in the dark, wheres your low pass filter at and what headunit do you have? |
