Thread: 99 s10 single cab sub size options |
Gold Member Username: Cblaze
Rock island,
Tenesssee
Us
Post Number: 2045 Registered: Sep-07
| Posted on Wednesday, April 23, 2008 - 01:08 am: |
what would fit in there. |
Silver Member Username: Kyle_lowe
Post Number: 896 Registered: Apr-06
| Posted on Wednesday, April 23, 2008 - 01:45 am: |
try out those new re shallow mounts  |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5513 Registered: Feb-06
| Posted on Wednesday, April 23, 2008 - 04:24 am: |
if you don't have a bench (which i assume you do) you could fabricate a new center console fairly easily. even if you do have the bench then you could do some cutting and such and fabricate a center console for the sub. either that or go the easy route with shallow mounts. re's should be good as well as realm audio. |
Rock island,
Tenesssee
Us
Post Number: 2046 Registered: Sep-07
| Posted on Wednesday, April 23, 2008 - 01:01 pm: |
dont have a bench but u can do woodwork without one. i got a jigsawlol.i can build boxes.its not that hard.i wanna keep all the seat space.i know i could prolly get 2 re 8's behind there ported..was just wondering if anybody had the dimensions of room behind the seat. |
