Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Someone smart please gimme a hand
Author Thread: Someone smart please gimme a hand
Username: Neyetmare
Post Number: 12
so my amp used to be hooked up to my factory deck through an rca adapter, now i bought a new deck and some cheap rca's from radio shack (which might be my problem), and it worked fine for about a week and all of a sudden the sub started cuttin out and would just randomly turn on even when i didnt have music playing. and now the light on my amp isnt turning on, not even the protect mode light. can someone tell me whats wrong?
Username: Kaerfpl
Spencerport, NY
Post Number: 897
Two things off the top of my head:
1. Amp may not be turning on. Check you REM wire.
2. Your amp is broken.
Username: Neyetmare
Post Number: 14
is there any possibility that its my rca's?
and how would i know if my amp is broken?
Username: Kaerfpl
Spencerport, NY
Post Number: 899
"and now the light on my amp isnt turning on, not even the protect mode light"
Two signs right there.
Im not sure if RCA's would deal with the amp not turning on.
Username: Neyetmare
Post Number: 15
k, i got an update and the logo on the amp turns on when i turn my truck on then dims out, and like 5 seconds later it turns on and dims out again.
and its a hi-fonics amp btw.
Username: Kaerfpl
Spencerport, NY
Post Number: 900
You probably just have a loose wire either at the amp or the battery. Check and make sure your ground has a clean and strong connection.
Username: Neyetmare
Post Number: 16
thank you so much dude, you really helped me out a lot
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Someone smart please gimme a hand [ « Previous ] [ Next » ]
