Thread: I need port advice... |
Silver Member Username: Hittin1
LakeCharles LA.,
La
Post Number: 206 Registered: May-07
| Posted on Tuesday, April 22, 2008 - 09:44 pm: |
I built two ported enclosures for my 12" solo x's and moved my big system into my 1999 Jeep Grand Cherokee. Big difference in sound... Way less flex also.0nly problem is when measuring the cargo space..my dumbass didn't take the wheel wells into consideration.. End result..... Boxes dont fit properly. By making the new boxes narrower , will need to make them taller to keep the same 6^3/ sub configuration. Finally... My question...How would yall think it would sound with subs up. And Port foward....right above rear seatbacks/headreasts? How would it effect the SPL(more important)... Thanks in advance. |
Silver Member Username: Surferdude9371
Im BTL Bumpin
Post Number: 833 Registered: Mar-07
| Posted on Tuesday, April 22, 2008 - 09:56 pm: |
id do sub up port back if its going in the jeep |
LakeCharles LA.,
La
Post Number: 208 Registered: May-07
| Posted on Tuesday, April 22, 2008 - 10:01 pm: |
I would but due to the depth of the enclosures... The ports would be too close to the back glass... |
Im BTL Bumpin
Post Number: 836 Registered: Mar-07
| Posted on Tuesday, April 22, 2008 - 10:04 pm: |
imo that would build pressure and sound good but i am NO EXPERT so deff get more votes |
LakeCharles LA.,
La
Post Number: 214 Registered: May-07
| Posted on Wednesday, April 23, 2008 - 12:18 pm: |
to the top |
Diamond Member Username: Bestmankind
Los Angeles,
CA
Post Number: 20491 Registered: Oct-05
| Posted on Wednesday, April 23, 2008 - 12:22 pm: |
try sub forward and port up top. it worked good in my friend's set up. the box needs to be pushed up against the back.
LakeCharles LA.,
La
Post Number: 215 Registered: May-07
| Posted on Wednesday, April 23, 2008 - 03:41 pm: |
Will crunch some figures with bassbox to see what is up0... Thanks Chad.. Right now they are sup and port up. Man it f'kn thumps HARD. It actually hurts! It should bein the 150 Db. range. Wont know for sure till next competition. Also need to upgrade alt.... AGAIN.. 160 amp just isn't cutting it! I will put up vids when I get new boxes built and carpeted. anmy other advice will be taken into consideration.. Thanks again! |
