Thread: Help |
New member Username: Tech36
Post Number: 9 Registered: Feb-08
| Posted on Tuesday, April 22, 2008 - 09:14 pm: |
hey i have a geo tracker and ive upgraded for about the 5th time and i have 2 15" audiobahns se from 2004, i was wonderin if anyone knew how many wats they can handle rms cause i found them at a local pawn shop and i was wonderin if a class d amp made a difference in the sound of a subwoofer at the moment i am powering just one of them with 400 watts at most and it pounds like a mofo and i was wondering what all i needed to do to make it shatter my front window if u know what i mean. |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5501 Registered: Feb-06
| Posted on Tuesday, April 22, 2008 - 09:25 pm: |
i would recommend upgrading a 6th time. |
Platinum Member Username: Chaunb3400
All he does is catch t...,
Alabama
U.S.
Post Number: 14170 Registered: Jul-05
| Posted on Tuesday, April 22, 2008 - 10:09 pm: |
^^Ditto |
Silver Member Username: Surferdude9371
Im BTL Bumpin
Post Number: 839 Registered: Mar-07
| Posted on Tuesday, April 22, 2008 - 10:13 pm: |
i agree upgrade but as far as what they can handle do you have the model number? or at least a pic of them so we can try to fig it out? |
Alabama
U.S.
Post Number: 14172 Registered: Jul-05
| Posted on Tuesday, April 22, 2008 - 10:15 pm: |
I believe they are dvc4ohm 400rms drivers |
Post Number: 10 Registered: Feb-08
| Posted on Thursday, April 24, 2008 - 12:16 am: |
ok well i cant do a pic of them so forget the speakers i guess, but does a class d amplifier make a difference instead of having a normal amplifier, idk i guess are ther advantages to a class d amplifier because they seem to cost way mor for the wattage and it looks like id have to wire it up for an 8 ohm load unless somebody knows otherwise. |
