Thread: New amp for highs |
Gold Member Username: Jakeyplaysbass
St. Louis,
MO / ASU
Post Number: 2625 Registered: Jul-05
| Posted on Tuesday, April 22, 2008 - 08:33 pm: |
Whats up boys... Im looking for a new amp for my frontstage. I was running 2 ED NINe.2xs which is around 400x2@4ohm. These amps are putting out enough power, but im looking for some better quality. So im looking for something that does around 300-350x2@4ohm that will be alot cleaner. Trying to spend under 700-800 bucks total and it can be 1 or 2 amps that get to the RMS needed. Some amps i was looking at... Zapco comp 6.0x used 2 Zapco comp 2.5x used 2 MMats sq 2125 used DLS A4 new 2 DLS A2 new Thanks for the help guys. |
Diamond Member Username: Bestmankind
Los Angeles,
CA
Post Number: 20479 Registered: Oct-05
| Posted on Tuesday, April 22, 2008 - 08:35 pm: |
you know my answer man. |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5498 Registered: Feb-06
| Posted on Tuesday, April 22, 2008 - 08:37 pm: |
you can't go wrong with any of those amps man. take your pick. i would probably go mmats just to match my sub amp. |
St. Louis,
MO / ASU
Post Number: 2626 Registered: Jul-05
| Posted on Tuesday, April 22, 2008 - 08:46 pm: |
A4 or A2s chadly? Thats why i would do the MMats Reece, i personally havent heard their frontstage amps tho...so idk. |
St. Louis,
MO / ASU
Post Number: 2627 Registered: Jul-05
| Posted on Tuesday, April 22, 2008 - 08:50 pm: |
I might just talk to my Hertz guy and try and get this guy in the price range... http://www.hertzaudiovideo.com/Doc/hertz_HP2_tech.pdf |
Los Angeles,
CA
Post Number: 20481 Registered: Oct-05
| Posted on Tuesday, April 22, 2008 - 10:09 pm: |
according to the shop where i get my stuff, the mmats amps are awesome. the A2 is a beast and having 2 of them would be killer. |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 4404 Registered: Jan-06
Kicker SX900.4 with SXRC remote. Has built in DSP, won't need anything extra and can be controlled from the driver's seat. Polo.. |
St. Louis,
MO / ASU
Post Number: 2629 Registered: Jul-05
| Posted on Wednesday, April 23, 2008 - 12:05 am: |
I like the Kicker amp Polo but i dont think it will be on the same level as the other amps listed. |
Chicago,
IL
US
Post Number: 4411 Registered: Jan-06
| Posted on Wednesday, April 23, 2008 - 12:23 am: |
There is only one thing I would choose over that amp and it would be the Zapco's. The Kicker SX A/B's are extremely clean, I have owned quite a few A/D/S plate amps and I have to say, I would put my money on the SX. JMHO...Polo.. |
Post Number: 5506 Registered: Feb-06
| Posted on Wednesday, April 23, 2008 - 04:02 am: |
paying all that dough for that hertz amp that you may not even showcase seems to be a little much. even if you did do some kinda of display with it or something it still wouldn't match your sub amp. maybe i'm just ocd, but that would get on my nerves. i know it will be incredibly clean and do exactly what you need it to, but unless you are turning into a serious audiophile i don't think its necessary plus i would have to have hertz sub amp if i had hertz comps, comp amp, and subs. |
Chicago,
IL
US
Post Number: 4417 Registered: Jan-06
| Posted on Wednesday, April 23, 2008 - 09:31 pm: |
Word^^^... Polo.. |
Gold Member Username: Skibum12189
Cleveland
Post Number: 2796 Registered: Mar-06
| Posted on Wednesday, April 23, 2008 - 09:37 pm: |
i've always been a fan of matching amps, but hey that's just me.. sorry to be OT, but did you decide on a new whip/ what speakers are you gonna be running that'll need 2x400 |
