Thread: 2 cvx or 2 RE SE12?? |
Silver Member Username: Dubmc23
Rapid City,
SD
Post Number: 243 Registered: Sep-07
| Posted on Tuesday, April 22, 2008 - 07:04 pm: |
i have a kicker kx1200.1 plz help me decide... |
Gold Member Username: Loudon
Post Number: 2385 Registered: Jun-04
| Posted on Tuesday, April 22, 2008 - 07:23 pm: |
cvx will get louder |
Rapid City,
SD
Post Number: 244 Registered: Sep-07
| Posted on Tuesday, April 22, 2008 - 07:26 pm: |
ok thanks |
Diamond Member Username: Bestmankind
Los Angeles,
CA
Post Number: 20470 Registered: Oct-05
| Posted on Tuesday, April 22, 2008 - 07:35 pm: |
i love the way the se's sound though. it still gets loud so i'd go with the se. |
Rapid City,
SD
Post Number: 245 Registered: Sep-07
| Posted on Tuesday, April 22, 2008 - 07:42 pm: |
i previously had two of the old type r's with the 1200.1 will the se's go louder then the r's?? |
Los Angeles,
CA
Post Number: 20472 Registered: Oct-05
| Posted on Tuesday, April 22, 2008 - 07:43 pm: |
it would be too close to call imo. i've owned both subs. the se sounds better than the type Rs though. |
Rapid City,
SD
Post Number: 246 Registered: Sep-07
| Posted on Tuesday, April 22, 2008 - 07:51 pm: |
yea those are did get pretty loud and they were only supposed to handle 300 rms each and i had them goto about 500rms a piece.. |
Silver Member Username: Hittin1
LakeCharles LA.,
La
Post Number: 205 Registered: May-07
| Posted on Tuesday, April 22, 2008 - 09:19 pm: |
both are good subs...Depending on size, U could use more power on the cvx's |
Platinum Member Username: Chaunb3400
All he does is catch t...,
Alabama
U.S.
Post Number: 14169 Registered: Jul-05
| Posted on Tuesday, April 22, 2008 - 10:00 pm: |
honestly Cvx>RE Se really depends on your listening habits and if you want something that everybody else has(cvx's) the CVX's get almost as loud as RE SX's..and sound decent in the lower mid and upper range..one of the best subs for the buck... |
Silver Member Username: Surferdude9371
Im BTL Bumpin
Post Number: 837 Registered: Mar-07
| Posted on Tuesday, April 22, 2008 - 10:07 pm: |
crx for spl re if your wanting cleaner sound |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 447 Registered: Sep-07
| Posted on Wednesday, April 23, 2008 - 11:31 am: |
cvx |
IL
Usa
Post Number: 452 Registered: Sep-07
| Posted on Wednesday, April 23, 2008 - 01:49 pm: |
if you're going for a pair of cvx 12s lemme know. I have one used I would part for pretty cheap and I know where you can get another for cheap as well. |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6322 Registered: Mar-04
| Posted on Wednesday, April 23, 2008 - 02:04 pm: |
I would have to go RE SE. I like their sound MUCH better. CVX's just don't do it for me. Both are nice subs though. |
