Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > Need help finding the right amp
Author Thread: Need help finding the right amp
Username: Piggy5891
Valley Cottage, New York
Im looking at gettting either a RE XXX 15" sub or an 18" sub, but heres the problem im not sure what amplifier would bring out the best in the sub. And what sub would you recomend an 18" or 15"
Username: Kingtutus
Lincoln, Nebraska
U.s.a
Post Number: 249
get the RD 3250.1D that would do a good job
Username: Stateprop486
PA
Post Number: 1473
do you have proper charging system? like h/o alternator and big 3 done?
Username: Piggy5891
nope i dont have a charging system yet, that was gonna be my next auestion
PA
Post Number: 1474
every car has a charging system but yours is stock. so if your running anything over 1000-1200 watts your going to need an H/O alternator and the big 3 done. how much is ur budget?
Username: Piggy5891
about $3500 that how much im willing to spend
PA
Post Number: 1475
all together for everything?
Username: Piggy5891
yeah
and i was looking at a hifonics sub the colossus one but would that go well with an 18" xxx sub?
Username: Talon01
Team Revolution , Pa
Usa
Post Number: 1174
how soon you looking to do this i have 2-rd3250.1 i will be selling soon. time for a upgrade for me
Username: Nyyfan13
15 MAG
Post Number: 9379
Hey Scott, let me know when your ready to sell one of those things bud. I might take one off your hands.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5481
weren't the old XXXs rated at 1500 watts? I mean given they will take more, but still the 3250.1 is a little overkill. Not to mention RD is not the be all and end all that timmy makes it out to be. I would go with mmats amplifiers way before I went with RD. they have a smaller footprint, more efficient, and they are way underrated. I would buy a new alternator before you buy any amps though. check out excessive amperage, ohio generators, mean green, and couple others.
Username: Talon01
Usa
Post Number: 1175
reece what do you think of sundown and xenon amps. the 3250 is 84% eff. whats wrong with that.
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 1982
I love my Sundown1500. great amp. very efficient too.
Username: Piggy5891
Post Number: 7
im prolly gonna be buying this within 3 months but im 100% sure i want the XXX series Sub cause they offer allotta bang even though they are expenisve..... but would you recomend another sub besides that
Username: 04redmach1
Lagrange, GA
Post Number: 1814
The old XXX were rated 1500 rms, and the new ones are rated 2000. Problem is, they are so inefficient, you need 2500+ to move the big woofer.
As for alts, I never liked Excessive Amperage, I have seen/heard way too many issues with them. I LOVE Ohio though :-)
Amp wise, the 3250.1 would be perfect. Gives head room and you can set gains low.
Kevin
lowhz01@yahoo.com
Username: Treez
Its not loud until it ...
Post Number: 329
Reece, i think Erik was referring to the newer model RE's...
Lagrange, GA
Post Number: 1815
Also, I am a RE dealer, so if you would like help on that woofer, shoot me an email.
Kevin
lowhz01@yahoo.com
Username: Loudon
Post Number: 2384
scott id also like for u to let me know ... when ur ready to sell .. cuz ill take one off ur hands
Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > Need help finding the right amp [ « Previous ] [ Next » ]
