Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > Big 3 upgrade
Author Thread: Big 3 upgrade
Username: Deadrabit
Post Number: 352
i found the wire to the alt to the battery.
but the wire from the battery to the ground and the ground to the chasy seem to be like one wire
it goes from the ground on the battery to the chaise and has a soldered place that grounds it like half way to the wire.
is this right?
its a vw golf 2000 if that helps any one
Username: Nd4spd18
Northwest PA
Post Number: 7424
So? You don't have to run the new wires to the same place as the stock ones. In fact I never do.
Username: Deadrabit
Post Number: 353
i already got it. thanks!
Username: Clouduz
Post Number: 338
sorry to hijack the thread, but for engine ground can i just pick a screw and ground it?
Username: Kklagge
San Diego
Post Number: 542
I would use a bolt on the frame...the ground is the most important part...you're going to the effort so do it right the 1st time.
Username: Clouduz
Post Number: 339
lol well i meant bolt but ok thnx so basically any bolt will work got it
Username: Kklagge
San Diego
Post Number: 543
a bolt on THE FRAME...not just a bolt on a flimsy piece of wheel well or something is your best bet.
Username: Deadrabit
Post Number: 355
my car doesn't have a frame
Home > Message Board > Car Audio > Subwoofers > Archive through April 26, 2008 > Big 3 upgrade [ « Previous ] [ Next » ]
