Thread: Is this a good box for 1 L7? |
New member Username: Youngk
Post Number: 7 Registered: Apr-08
| Posted on Monday, April 21, 2008 - 07:57 pm: |
http://www.sonicelectronix.com/item_7285_12-+Square+Hole%2C+Long+Rear+Slot+Porte d+Enclosure+for+Kicker+Solo-Baric+L5+-+L7+Subwoofers+-121KP-.html |
Gold Member Username: Mgbcs
Lincoln,
Nebraska
Post Number: 2435 Registered: Dec-06
| Posted on Monday, April 21, 2008 - 08:00 pm: |
I would advise you to make your own. It will be higher quality. |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5469 Registered: Feb-06
| Posted on Monday, April 21, 2008 - 08:10 pm: |
most pre-fab boxes are no good. if i added it up right that box is tuned pretty damn high. |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 803 Registered: Aug-07
| Posted on Monday, April 21, 2008 - 08:55 pm: |
if you get a box made to the specs of the sub, its gauranteed to be better than a prefab box. |
Post Number: 8 Registered: Apr-08
| Posted on Monday, April 21, 2008 - 09:01 pm: |
I'm sorry I'm kinda new...isn't the box made for the l7? Shouldn't it already be ported and tuned correctly? |
DUB-C,
TX
Post Number: 804 Registered: Aug-07
| Posted on Monday, April 21, 2008 - 09:06 pm: |
that one will make the L7 sound like crap (they dont get very good SQ anyway) |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 857 Registered: Jul-07
| Posted on Tuesday, April 22, 2008 - 11:17 pm: |
the only prefabed box i would recomend would be the bass slammer series. but other then that build your own box will be better |
Gold Member Username: Tatonka
-[Team Audib...
Post Number: 1621 Registered: Mar-07
| Posted on Tuesday, April 22, 2008 - 11:38 pm: |
"the only prefabed box i would recomend would be the bass slammer series" And why is that? Some prefab boxes get the job done. If you can't make your own and you don't have a high enough budget to get someone to make it, what other choices do you have? |
