Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Need a Good 800watt Amp
Author Thread: Need a Good 800watt Amp
Username: Silvermopar
Nebraska
Post Number: 76
Alright I would like to buy a decent 800watt 2ch 2ohm amp. I would like to run a pair of 12" Kicker CompVRs with it. they are rated 800watts peak per sub and like 400watts rms each I think, and 2ohms. I would like to keep it UNDER $160 if thats possible.
Suggestions as to what to and what not to get would be helpful. Thanks
Username: Drant19
DUB-C, TX
Post Number: 796
are the cvr's dual2ohm? dont buy a 2channel amp. what you want is a class D mono amp. 160 isnt much, maybe try to save up a little more!
Nebraska
Post Number: 77
The subs are dual voice coal, Idk where the 2ohms is it just says that on each magnet on back
Username: 04redmach1
Lagrange, GA
Post Number: 1810
They are dual 2 then. Can you go $275 for an amp?
Kevin
Nebraska
Post Number: 78
I really dont want to... The $70 amp i have is great at above half volume. Its just that when i turn it down so that i can hear other ppl in the vehicle, the sound is so sh1ty i cant stand it. I think its just the amp. But you dont know of something decent (doesent have to be the best) for a good ways under $200 that will power um nicely?
Username: Drant19
DUB-C, TX
Post Number: 799
do you have a sub control on your HU? the amp isnt going to give you better sound quality. try a different box. what kind of box do you have?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5297
well bro.. stick to your amp until you can afford a better amp. You need around 250-300$
Username: Drant19
DUB-C, TX
Post Number: 806
zx750.1 refurb rings a bell...
find those on ebay
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 495
audiobahn a8000t if your on a budget of 160, i think it can be had for les than that and does pretty close to rated power
Username: Drant19
DUB-C, TX
Post Number: 810
kicker refurb > audiobahn ANYDAY!!
Nebraska
Post Number: 79
I love Kicker, but thats a single ch amp your reccomending there is it not? I think i need a 2ch... Maby not
Username: Pbplayer05
Carroll, Iowa
Post Number: 608
no u need a mono
Nebraska
Post Number: 81
so I would end up hocking the speakers Parallel? therefore cutting the ohms from the amp in half?
Nebraska
Post Number: 82
I just checked on those amps. I like the price pretty well. But how would I run 2 subs (i only use a single channel of each) off of a single channel amp
Username: Chaunb3400
All he does is catch t..., Alabama
U.S.
Post Number: 14174
Or you can buy my RD Audio 1000.1, that i have not used since i got it from Chad...
Nebraska
Post Number: 83
how much for it? and how do we make the transaction
Username: N2audio
Lawrence, Ks
Post Number: 1534
"how would I run 2 subs (i only use a single channel of each) off of a single channel amphow would I run 2 subs (i only use a single channel of each) off of a single channel amp
Like this
http://www.rockfordfosgate.com/rftech/woofer_wizard/2_2ohmDVC_2ohm.gif
You can run as many subs as you want off a mono amp -- you just have to wire it for the appropriate impedance using series and/or parallel wiring.
U.S.
Post Number: 14175
I can do $200shipped for you :-)
I take paypal or money orders...
http://www.rdaudio.net/rd1000/rd1000.htm
Nebraska
Post Number: 85
I understand how ohms change when you hock speakers in series and parell. But i do not understand what happens to the watts that each recieves. I would like to give the subs no more than 400 watts rms a piece. would each sub actually recieve 750 watts rms off that amp no matter how i wire it?
Username: 420alldaylong
Post Number: 3523
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19509
50x2 @ 4ohm stereo
100x2 @ 2ohm stereo
150x2 @ 1ohm stereo
200x1 @ 4ohm bridged
300x1 @ 2ohm bridged
This amp is a little monster WAY underated power.
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Need a Good 800watt Amp [ « Previous ] [ Next » ]
