Thread: DO I need an amp?! |
New member Username: Techfizzle
Post Number: 1 Registered: Apr-08
| Posted on Monday, April 21, 2008 - 12:21 am: |
My fronts are 2-25 rms rears 2-100 rms my deck is 200 watts max 88 rms. Do i need an amp to listen at a louder then normal level? |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 895 Registered: Jun-06
| Posted on Tuesday, April 22, 2008 - 09:59 pm: |
what deck do you own? |
Post Number: 2 Registered: Apr-08
| Posted on Tuesday, April 22, 2008 - 10:04 pm: |
kenwood kdc-mp208 200 watts max |
Spencerport,
NY
Post Number: 896 Registered: Jun-06
| Posted on Tuesday, April 22, 2008 - 10:08 pm: |
RMS Power Output for that deck is 22 watts. Your front speakers are fine, but you can put an amp on your rears if you need it. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1535 Registered: Mar-04
| Posted on Tuesday, April 22, 2008 - 11:31 pm: |
That deck's not cea compliant. Probably more like 12-15 x 4. You might consider a little 50x2 for the fronts, but I'd leave the rears alone. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5301 Registered: Dec-05
| Posted on Wednesday, April 23, 2008 - 08:21 pm: |
i'd use a small amp. IMO Head units are not a good choice when pushing speakers. |
