Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Suggestions on an amp for 2 RE audio 12s
Author Thread: Suggestions on an amp for 2 RE audio 12s
Username: Ballercec
Clinton, NC
Post Number: 21
The subs are rated at 600rms each and are dvc 4 ohms and i was told to look for a monoblock amp and run them down to one ohm. Any suggestions??
Relevant Product Info
Username: 420alldaylong
Post Number: 3522
Budget?
Username: Ballercec
Clinton, NC
Post Number: 23
125-200 dollars is what i'm looking at for an amp for the two subs
Username: 04redmach1
Lagrange, GA
Post Number: 1802
Had to edit, I wasn't reading. You need a 1000rm amp. The RD 1000D would work great, but $325 shipped. Can you increase your budget?
Kevin
lowhz01@yahoo.com
Username: Nd4spd18
Northwest PA
Post Number: 7415
I would get an Audioque 1200d for $249
You will not find a good amp cheaper than that.
Username: Ballercec
Clinton, NC
Post Number: 27
Someone mentioned a Hifonics BXI 1606d or 1206d. what are you opinions on these amps with the subs i'm interested in?
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Suggestions on an amp for 2 RE audio 12s [ « Previous ] [ Next » ]
