Thread: DHD, Quantum Audio, Sound Storm |
New member Username: 4realadeala
Tampa,
Florida
Post Number: 1 Registered: Mar-08
| Posted on Sunday, April 20, 2008 - 06:55 pm: |
Yes I know that they are garbage compared to other brands but for 150 bucks which one is probably better. Please I have used forums before and people tend to ramble about the first sentence rather than the point of the question. So feel free to ramble but if you do answer the question. |
Relevant Product Info
Platinum Member Username: Chaunb3400
All he does is catch t...,
Alabama
U.S.
Post Number: 14156 Registered: Jul-05
| Posted on Sunday, April 20, 2008 - 07:08 pm: |
first thing is what are you trying to power...and to answer the question they are all in the same boat... no point in wasting your $150 |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7411 Registered: Jul-06
| Posted on Sunday, April 20, 2008 - 07:50 pm: |
Not only are they bad quality you won't get anywhere near the power they claim. |
Tampa,
Florida
Post Number: 4 Registered: Mar-08
| Posted on Monday, April 21, 2008 - 04:18 pm: |
Yeah I am aware that they are liars. But when you say bad quality do you mean that they don't play the frequency the same way as a better quality amp? Or do you mean that they cut out? But just for arguments sake, which one is probably the most reliable? |
Gold Member Username: 04redmach1
Lagrange,
GA
Post Number: 1808 Registered: Mar-06
| Posted on Monday, April 21, 2008 - 05:17 pm: |
Tell us what you want to power. Need to make sure you won't kill anything. Is $150 the most you can put into an amp? Kevin |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5298 Registered: Dec-05
| Posted on Monday, April 21, 2008 - 09:15 pm: |
i agree with kevin... you can always buy refurbished |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1537 Registered: Mar-04
| Posted on Tuesday, April 22, 2008 - 11:38 pm: |
I bought a used DHD for my boat and I've been pretty impressed. Soundstorm's ratings are so ridiculous it's hard to even speculate on their actual output. One of their $200 mono's is rated for 2300w rms and has an 80A fuse -- WTF?? I know nothing about QA except that the only amps they have that look relatively interesting are the Titaniums, and I doubt they're very cheap. |
Post Number: 5300 Registered: Dec-05
| Posted on Wednesday, April 23, 2008 - 08:19 pm: |
We know they can work in small applications... i've messed even with legacy and they work.. but in the long term they die. Tell us what are you trying to push.. I insist |
