Thread: Sony Cd Player not working |
New member Username: Mat_1992
Post Number: 1 Registered: Apr-08
| Posted on Saturday, April 19, 2008 - 09:25 am: |
I just bought a car and it already had a sony cd player in it it was working perfectly fine until the other day i turned the ignition on and nothing lit up on it i checked all the fuses and everyhting, the only thing i can do is insert cd's and eject them, the radio doesn't even work... PLease help me.} |
Relevant Product Info
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1095 Registered: May-07
| Posted on Saturday, April 19, 2008 - 07:27 pm: |
hmm does it have a face plate? if so sounds like the contacts are worn, take the face off and check the contacts and be careful ! if u need to bend them. other then that a wire came loose and u'll need to pull the radio out to fix it. |
Post Number: 2 Registered: Apr-08
| Posted on Saturday, April 19, 2008 - 11:03 pm: |
Ok i'll see if that will fix it. Thanks |
