Home > Message Board > Car Audio > Multimedia Systems > VM9312 - NO AUDIO AFTER FIRMWARE UPGR...
Author Thread: VM9312 - NO AUDIO AFTER FIRMWARE UPGRADE!!!
Username: Israelleite
My device was working fine until I decided download the firmware upgrade from www.audiovox.com/downloads Since then my vm9312 won't play any
audio anymore. Does anybody experienced this problem before? Do you know if there is a fix for it? Thank you.
Relevant Product Info
Username: Blackwag
i did the same thing,had to send it back to jensen,they had to replace it......sorry
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Multimedia Systems > VM9312 - NO AUDIO AFTER FIRMWARE UPGR... [ « Previous ] [ Next » ]
