Thread: Best Battery for My system |
Bronze Member Username: Hddvd
Post Number: 29 Registered: Nov-07
| Posted on Tuesday, April 15, 2008 - 07:37 pm: |
I just got a 1000w RMS mono amp with a 550 watt 4 channel amp. When i play any music lound my lights dim. I was wondering if i get a new battery if that would help any. I have a dry cell right now. I was looking into a Kinetic or Optima. I only listen to the music loud when im driving, not stationary. Thanks for any help. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7370 Registered: Jul-06
| Posted on Tuesday, April 15, 2008 - 08:18 pm: |
You need an HO alternator. A good battey like a Kinetik or Odyssey (not optima) wouldn't hurt though. |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 7956 Registered: Jul-06
| Posted on Wednesday, April 23, 2008 - 08:59 am: |
Optima batteries are still good but stay away from the red tops for car audio. Hell, even some world records were set with Optima batteries. |
Bronze Member Username: Levelzero
Post Number: 21 Registered: Aug-07
| Posted on Wednesday, April 23, 2008 - 11:21 am: |
Are capacitors still good to use these days? Thus, being a possible solution? I remember having one installed when I was running two 12" Kicker subs on a MTX Thunder Amp, along with a Kenwood Mid. This was more like a little over 10 years ago. |
I compensate...
Post Number: 7962 Registered: Jul-06
| Posted on Wednesday, April 23, 2008 - 03:57 pm: |
"Are capacitors still good to use these days? Thus, being a possible solution? I remember having one installed when I was running two 12" Kicker subs on a MTX Thunder Amp, along with a Kenwood Mid. This was more like a little over 10 years ago." No, people don't really use capacitors anymore if they know how they truly work. In some cases a crazy amount of capacitors or farads is useful but for the most part capacitors are useless. |
New member Username: Canuhearme
New rochelle,
Ny
United staes
Post Number: 1 Registered: Jun-08
| Posted on Monday, June 23, 2008 - 11:30 pm: |
i have 2 kinetik batters 1 is hc1400 thats for the front the other is hc2000 will my alt charge both batteries without using an isolater |
