Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Install kit
Author Thread: Install kit
Username: Will4992
NC
Post Number: 21
http://www.sonicelectronix.com/item_6240_Absolute+KIT1450.html
Is this a good kit to install my jl 1000/1 with or should i look for something else?
Username: Nd4spd18
Northwest PA
Post Number: 7350
Don't buy an off brand wiring kit, most times they lie about the wire size, it will have a thick casing and not enough copper.
You can't go wrong with kicker wiring kits and you can get them for reasonable prices on ebay.
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Install kit [ « Previous ] [ Next » ]
