Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Opinion on MMats...
Author Thread: Opinion on MMats...
Username: Treez
Its not loud until it ...
Post Number: 320
I've got 2 15" mags(d2) and i am trying to determine which mats amp to buy to adequately push them.
I hope to avoid buying the 1/2 ohm versions. So i've decided on a D2100.2.
Do you guys think that amp would sufficiently power both subs?
And does anyone know the actual output on this amp(websites quote 1550rms)...
Thanks
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5284
well bro that's a great brand but IMO.... why don't you try kicker ZX 2500.1
i think the mmats 3500D is one ohm stable.
You can use mmats by getting two (1ohm stable amps)
Username: Th3pwn3r
I compensate...
Post Number: 7915
MMATS amps are top notch. The D3000.5(Half ohm stable) and the D3000.1(One ohm stable) that I've used were super efficient and put out more power than a Memphis 4Kw amp while sucking FAR less current. They were modded though but MMATS amps are no joke and the power to size ratio is just insane.
Username: Treez
Post Number: 321
I'd prefer one amp and i am going with mmats.
How much watts do you figure i 'll get from the 3000.1 at 2 ohms?
Thanks
Username: 04redmach1
Lagrange, GA
Post Number: 1770
MMats is for sure good stuff. I would go MMats before Kicker IMO.
Kevin
Username: Nyyfan13
15 MAG
Post Number: 9288
The Mags will be good off about 800rms a piece from that amp. Real nice system bud.
Username: Treez
Post Number: 322
Yeah Kevin. There's no doubt about that.
Hey Yanks, how much is your mag seeing...and what amp are u currently using?
kevin, im trying to buy an amp with the RD alpha v2 in mind also, as i would be trying that sub out probably after i preview the new shallow mount mag ...
What's the most i can safely run on the alpha V2?
Username: Treez
Post Number: 323
Im not seeing the D3000 mats amp on their website.
Does anyone know how much of a power difference there is, between the D3000.1 and the D2900.1 amps?
Username: Nyyfan13
15 MAG
Post Number: 9302
I'm giving my Mag just about 1000rms from a Hifonics 1206d. In a few months, I'll be giving it 900rms but on a much better amp.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5286
i know mmats is better... i was just saying cuz i didn't know mmats has a 3000w rms amp two ohms.
Username: Goodie_goop
Mid town, Texas
U.S.
Post Number: 853
my 800.1 does me good lol :-)
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Opinion on MMats... [ « Previous ] [ Next » ]
