Thread: Problem with amp |
Bronze Member Username: Deserteagle50cal
Post Number: 39 Registered: Jun-06
| Posted on Sunday, April 13, 2008 - 12:18 pm: |
My amp will not cut off unless I pull the remote wire out. I put the wire in and it comes on. The radio is off the whole time. Isn't that backwards from what the remote wire should do? I have had the amp hooked up for about 5 months and never had a problem til 3 days ago when it started draining my battery. The amp is an Earthquake PHD5000. Please help if anyone knows what it could be. |
Silver Member Username: Mmaudioconcepts
Post Number: 466 Registered: Jan-07
| Posted on Sunday, April 13, 2008 - 12:46 pm: |
what is powering your remote wire? is it ocnnected to the head unit or a fuse? if its the head unit, make sure its the right wire(usually blue w/white stripe. If its a fuse then make sure its a a fuse that sees 12v only when the key is turned. |
Post Number: 467 Registered: Jan-07
| Posted on Sunday, April 13, 2008 - 12:47 pm: |
also if any of the strands from the power wire are touching the input for the remote on the amp, you would get this problem. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5279 Registered: Dec-05
| Posted on Sunday, April 13, 2008 - 01:56 pm: |
your remote is getting 12V when your car is off. |
Post Number: 40 Registered: Jun-06
| Posted on Sunday, April 13, 2008 - 03:20 pm: |
The headunit is powering the remote wire. It is definately blue with white stripe. I will double check to make sure the power wire is not touching the input for the remote. Thanks guys. Anymore ideas let me know. |
Post Number: 468 Registered: Jan-07
| Posted on Sunday, April 13, 2008 - 03:47 pm: |
if you mounted the amp on the sub box, it could have rattled components on the inside of the amp to touch that shouldn't be touching |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7336 Registered: Jul-06
| Posted on Sunday, April 13, 2008 - 04:31 pm: |
Earthquake amps are not good quality at all so in this case I would not be surprised if it is an internal failure. Check your remote wire with DMM first though. |
