Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Difference between f250 and f300 amps...
Author Thread: Difference between f250 and f300 amps???
Username: Milnerj
Saint Louis, Missouri
United states
Post Number: 9
Hey,
I was wondering what the difference between these two amps are? On alpines homepage they cost the same amount of money but the 300 spits out 50x4 at 4 ohms while the 250 only puts out 40x4 at four? I'm not sure what the difference could be? if someone could help me soon i'd really appreciate it, i need to make a decision on which one to buy fairly quickly so i can get my install on the road!
thanks in advance,
Joe
[*EDIT*] heres the alpine page for the f250...
http://www.alpine-usa.com/US-en/products/product.php?model=MRP-F250
and heres the page for the f300...
http://www.alpine-usa.com/US-en/products/product.php?model=MRP-F300
Username: Nd4spd18
Northwest PA
Post Number: 7326
Well obviously you want the F300 since it does more power.
Username: Milnerj
United states
Post Number: 10
but why would alpine produce an amp with less power for the same price??? theres got to be a reason otherwise why would people by the f250
Username: Nd4spd18
Northwest PA
Post Number: 7335
Newer model probably
Username: Milnerj
United states
Post Number: 12
on the website it says the f250 is mosfet and the 300 isnt... whats that mean?
Username: Nd4spd18
Northwest PA
Post Number: 7380
They both are thats the technology class D amps use. If they are both the same price then the 300 is the obvious choice.......
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Difference between f250 and f300 amps... [ « Previous ] [ Next » ]
