im trying to hook up my stock amp because if i dont i cant use the warning system or door chimes and its my wifes car if she cant hear something going wrong then she probably wont tell me about it and blow the car up so i need to hook up the stock amp and my deck dosent have high speaker wires and the stock amp has highs only and the wiring harness is the same.
you need a door chime adaper, google it. don't mess with that stuff u can really screw the car up. you need a adapter cause those chime systems are wired into everything and can even screw with a cars ECU. so do it right find the adapter, probably at crutchfield.com.
