Thread: What amp should I get? |
New member Username: Sorrowharvester
Independence,
Missouri
U.S.
Post Number: 2 Registered: Apr-08
| Posted on Thursday, April 10, 2008 - 10:47 pm: |
I am about to install 2 BL15 dual 1 or 2 ohm and i would just like to know what would be the best choice for an amp or amps. Thanks. |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1416 Registered: May-07
| Posted on Friday, April 11, 2008 - 01:19 am: |
It depends on what amp you are using. |
Gold Member Username: 04redmach1
Lagrange,
GA
Post Number: 1753 Registered: Mar-06
| Posted on Friday, April 11, 2008 - 02:21 am: |
Grab dual 1's and get an amp that is stable at 1 ohm with arund 2000rms. Kevin |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5278 Registered: Dec-05
| Posted on Sunday, April 13, 2008 - 02:21 am: |
or dual 2 ohm and grab a kicker zx 2500.1 |
Platinum Member Username: Chaunb3400
All he does is catch t...,
Alabama
U.S.
Post Number: 14138 Registered: Jul-05
| Posted on Sunday, April 13, 2008 - 03:40 am: |
http://www.audioque.com/aq/AQamps2200D.htm |
