Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > 3000wrms
Author Thread: 3000wrms
Username: Mmaudioconcepts
Post Number: 453
what are some amps that put out 3000wrms @ 1,2 or .5 ohm
Username: 04redmach1
Lagrange, GA
Post Number: 1754
RD Audio 3250.1 would work for ya :-)
Kevin
Post Number: 455
any other suggestions? or comments on the kicker zx2500.1 or the crunch GP3000D?
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 1594
crunch?
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 1596
I have a kicker kx2500.1. its been a great amp. the birth sheet said 2880 watts.
Username: Mixmastaspig
Team RD, Canada
Post Number: 1619
RD is really soild, Kicker would be not a bad choice either thought I think the RD will do more power as the Kicker can't (shouldn't) go below a 2ohm load.
Kicker zx2500.2 = 2500rms @ 2 ohm
RD 3750.1 = 3000rms @ 1 ohm
Stay away from Crunch I have not heard anything good about that company.
Mmats are supposed to be crazy good amps
D3500.1 = 2700 Wrms @ 1 ohm
Username: Ctmike
Ct.
Post Number: 5958
sundown saz3000d.
Lagrange, GA
Post Number: 1756
Yea, we are getting around 3500-3800 rms out of the 3250's at 1 ohm at 14v :-)
Kevin
Post Number: 456
i just need between 2500 and 3000,and on this forum i have heard great things about the crunch3000D alone, i know that their other products are questionable, i am by no means a noob in this field i just simply wanted to expand my list of ~3000watt ams so i didnt miss any an not consider them.
Team RD, Canada
Post Number: 1620
Well Hifonics, Crunch, Mb Quart are all owned and operated by Maxxsonics. So you could check out the Brutus BXi 2608D as well.
I wasn't saying noob or anything as I can't recall hearing anything great about Crunch products and I don't want to steer people into bad/faulty lines of equipment.
Lagrange, GA
Post Number: 1757
Well, tell us this, what is your budget for the amp?
Kevin
Post Number: 457
i budget 1000/month for leisure, but i have like a 600-700(for the amp) budget because i dont want to wait.
Lagrange, GA
Post Number: 1759
If you can put up a little more, I can help you with a RD 3250.1 or Sundown SAZ-3000D. Shoot me an email.
Kevin
lowh01@yahoo.com
Post Number: 458
kevin, im going to push back my system, i will talk to you before i buy my amp. im going to save about $8,000 for my setup so it will be a few months. reason is because the electrical system in my truck is fried and im having problems finding someone to fix it.
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1508
AQ3500D
If it is made
Username: Nyyfan13
15 MAG
Post Number: 9244
The new Crunch GP3000D is supposedly a real solid amp. Do some research on it and you'll see.
Post Number: 463
^^^thats what i have hear/read too
Boca Raton, Florida
Post Number: 1515
"Ok guys, here it is. Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts. NOW WHAT DO YOU THINK ABOUT THAT!"
Eric From Team Live Wire Wrote that
Wow i gotta say im impressed.. Crunch putting out number like that.. Amazing neva thought i'd see they day, what is Next Sony actually making good subs and amps lol
Username: Hdubb
Team Revolution
Post Number: 3551
lots of good amps. and actuallyu ive heard of a lot of competitors running the kx2500.1s at .5 ohms
list lol
rd 3250.1
sundown saz3000d
atomic 3000.1d
(all same amp btw)
mmats 3500.1 or 3500.05
crunch gp3000d
dd m3
american bass 200.1
stetom 2k6
dd z1a
ia 40.1
db drive ph2000
kx2500.1
err i cant think so many more
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5275
considering the amount of money he's saving... forget about crunch, i know it's a good model.. but c'mon. I'd grab American bass ASAP or mmats
Post Number: 465
where can i buy american bass and how much does it usually cost
Post Number: 469
bump
Username: Nd4spd18
Northwest PA
Post Number: 7337
American Bass amps you can find used on caraudio.com or ebay. They don't sell those amps new to the public.
Post Number: 470
what would everyone get between
Massive Audio P3000.1
Crunch GP3000 Pro
MA HK4000D
Kicker2500.1
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5285
based on reputation/quality
1- kicker ZX 2500.1
2- massive audio p3000.1
3-Crunch GP 3000d
4- Ma Audio (HELL NO DON't consider this sh1t lol!)
with your budget... please buy something with good quality.
Username: Nd4spd18
Northwest PA
Post Number: 7339
Kicker by far........ thats no contest. MA audio is crap btw.
And LOL at that crunch "benchtest"....... you can't accurately benchtest an amp with a reactive load.
Post Number: 473
im leaning towards the massive.
Team RD, Canada
Post Number: 1624
After hitting up the term pro site the Crunch amp doesn't sound like too bad of an amp and can be bought for $485 off ebay.
Just go with what fits your budget,needs and what you like the best.
Post Number: 475
im OCD about matching amps so im getting the massive p3000 to power my BLs and the massive 800.4 to power my two sets of diamond hex comps
Username: Jkidder
Gunshine , State
Flawda
Post Number: 3458
id love to see a birthsheet that says 3500-3800 rms at 1 ohms for a rd 3250. i doubt it!
the cisco kid
Username: Nd4spd18
Northwest PA
Post Number: 7348
FYI that massive is overrated a little, they do ~2800w maximum
Post Number: 476
thats enough, thanx
Username: Chaunb3400
All he does is catch t..., Alabama
U.S.
Post Number: 14139
I dont trust any bench test sheet that is hand written out of somebodies shop...Its just so easy to make that 3 look like an 8, catch my drift..
Find an Orion 2500D or Kicker Kx2500.1 and call it a day...
Username: Insearchofbass
Post Number: 8951
If I remember right someone on here had trouble running a massive 3000 because they said it was current hungry
Username: Nd4spd18
Northwest PA
Post Number: 7363
Yeah they are not real efficient. Those amps are cheaper for a reason, you get what you pay for.
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > 3000wrms [ « Previous ] [ Next » ]
