Thread: Mounting amp |
Bronze Member Username: Diehlerman
Post Number: 60 Registered: Jan-08
| Posted on Thursday, April 10, 2008 - 03:05 pm: |
has anyone mounted their amp on the back of their sub box? would this hurt the amp in any way? |
Relevant Product Info
Gold Member Username: Mixmastaspig
Team RD,
Post Number: 1617 Registered: Sep-05
| Posted on Thursday, April 10, 2008 - 03:16 pm: |
The sub box will flex and vibrate and can cause your amps internals to vibrate as well. You can wreck amp this way (from what I have heard) but I have never done it personally, I just use the back of a seat or ground. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7311 Registered: Jul-06
| Posted on Thursday, April 10, 2008 - 07:34 pm: |
Never mount amplifiers to the box. Vibration = bad for electronics. Back of the seat is usually easiest, if you want to do the work the best thing is to make an amp rack. |
Bronze Member Username: Chaosofthemasses
Edwardsburg,
Michigan
Usa
Post Number: 20 Registered: May-08
| Posted on Friday, May 16, 2008 - 01:54 am: |
for once i totally agree with MS,WOOO, ive had a bad experience with an amp being on top of the sub box and it rattled my amp right out of commision but it took a lil while for it too happen but none the less it happened. usually the best spots are the left rear or right rear of the trunk if possible or right behind the rear seats. |
Bronze Member Username: Dupe112309
Post Number: 82 Registered: Feb-08
| Posted on Saturday, May 17, 2008 - 10:04 am: |
oops i mounted mine on the back of the sub box. its ported and it doesn't feel like its vibrating though. |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 955 Registered: Aug-07
| Posted on Saturday, May 17, 2008 - 06:36 pm: |
chris duprey, -take that amp off and put it on the back of a seat. |
