Thread: Mutant nw280sp- wiring+impedance help |
New member Username: Wingnutter
Post Number: 1 Registered: Apr-08
| Posted on Thursday, April 10, 2008 - 12:56 pm: |
Hey there, A couple of years back i purchased a mutant nw280sp amp and have recently purchased a mutant mt1205 subwoofer. The specs for the amp are the following: * 2 channel amplifier * 2 x 80w RMS at 4 ohms * 1 x 160w RMS at 2 ohms and the sub: • 12” (300mm) IMPP Cone with Rubber Edge • 50oz Magnet • 2” Heat Resistant Kapton Voice Coil • Input Power: 120W RMS / 250W MAX • Frequency Response: 25Hz-2KHz • Impedance: 4 Ohms • Sensitivity: 90dB • Gold Plated Round Terminals for Quick Connection At the moment, from an old configuration, the sub is connected to the amp via a bridged connection. Does that mean that the amp is running at 1 x 160w RMS at 2 ohms? Since the sub is rated with an impedance of 4ohm, how would i change the wiring so that the sub runs at 2ohm to correspond with the 1 x 160w RMS at 2 ohms of the amp, if that makes any sense Any help or feedback will be greatly appreciated |
Bronze Member Username: Waresgaragestereo
Fort Valley,
GA
Post Number: 90 Registered: Mar-08
| Posted on Monday, April 14, 2008 - 12:49 am: |
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=1DV C%5F2%2Dohm%5F2ch go to this link |
