Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > What wiring kit do i need and is my a...
Author Thread: What wiring kit do i need and is my amp ok for the load?
Username: Hendry91
Leatherhead, Surrey
United Kingdom
Hi, i have just bought a Alpine type r sub, Alpine type r 6x9s, some Kenwood in door speakers and i bought a Toxic TX-1200N 1200 watt amp. Can i wire all of these speakers to the amp and what wiring kit would i need, any help would be grateful.
Thanks for your help
Username: Wylie_coyote
Post Number: 185
wiring the sub and the 6*9's to the same amp is not a good idea. You'll end up damaging the something.
You have a to have two or 3 amps for your setup. 1 for the sub, and one for 6*9 and doot speakers. you could run these on separate amps if you wanted as well.
My knowledge on the Type R subs isn't too great but from what i've heard these bad boys can take a lot of punishment so you might need to buy a new amp to get the most out of it.
with regards to wire gauge, heres a link with some information on it http://www.bcae1.com/wire.htm
Username: N2audio
Lawrence, Ks
Post Number: 1530
that looks like a basic 4 ch amp.
What you can do is bridge two channels to run the sub (we would need to know whether it's the 2 or 4 ohm version to tell you how it needs to be wired).
And you can run the 6x9's and door speakers on the other 2 channels.
An 8 ga amp kit MIGHT work ok, but to be sure it would probably be a good idea to go with 4 ga, plus it would give you room to add another few hundred watts worth of amp power in the future.
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > What wiring kit do i need and is my a... [ « Previous ] [ Next » ]
