Thread: 95 s-10 front door speakers. |
Gold Member Username: Cblaze
Rock island,
Tenesssee
Us
Post Number: 1993 Registered: Sep-07
| Posted on Wednesday, April 09, 2008 - 11:34 pm: |
sonicelectronix says it needs 6 3/4 inch speakers.if thats right whats a good set of components in that odd ball size prefferably 150 or less |
Rock island,
Tenesssee
Us
Post Number: 1994 Registered: Sep-07
| Posted on Wednesday, April 09, 2008 - 11:40 pm: |
then crutchfield says 6.5 with modifactions or a backet does anyone know what size i need |
Silver Member Username: Exige
Cincinnati
Post Number: 240 Registered: Nov-07
| Posted on Thursday, April 10, 2008 - 12:40 am: |
just go with 6.5", you'll be fine with that. |
Rock island,
Tenesssee
Us
Post Number: 1995 Registered: Sep-07
| Posted on Thursday, April 10, 2008 - 09:51 am: |
do you need the bracket like crutchfield says? |
Cincinnati
Post Number: 242 Registered: Nov-07
| Posted on Thursday, April 10, 2008 - 03:59 pm: |
typically on a 6.5 vs 6.75" situation....the speakers mount right in. I can't give you a for sure answer since I haven't personally dealt with your car...give Crutchfield a call and see how big of a deal they think it is. |
Rock island,
Tenesssee
Us
Post Number: 2003 Registered: Sep-07
| Posted on Thursday, April 10, 2008 - 11:52 pm: |
i will give that a try |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1618 Registered: Jan-06
| Posted on Friday, April 11, 2008 - 04:10 pm: |
it requires an adapter but its also pretty shallow IIRC. Finding a good mix of those may be an issue. I would look into a shallow mount set like CDT, MB Quart, or the Illusions on ebay. Email me though at sales@alteraudiousa.com if you have questions about speakers especially CDT. |
Rock island,
Tenesssee
Us
Post Number: 2018 Registered: Sep-07
| Posted on Saturday, April 12, 2008 - 11:24 pm: |
speakers is out of the question right now.im gonna have to spend alot of money to get the truck going |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7345 Registered: Jul-06
| Posted on Monday, April 14, 2008 - 03:21 pm: |
Yeah, in those trucks you don't have a lot of depth due to the window track being behind the speaker. |
Rock island,
Tenesssee
Us
Post Number: 2030 Registered: Sep-07
| Posted on Monday, April 14, 2008 - 10:41 pm: |
i will figure out somethang when the tiome comes.i might just go with dash speakers.its simpler to just get some 4 inch components for the dash |
