Thread: Subs cutting out |
Bronze Member Username: Diehlerman
Post Number: 49 Registered: Jan-08
| Posted on Tuesday, April 08, 2008 - 12:26 am: |
my girlfriend has 2 10 CVR'S being pushed by a zx750.1 in her jeep and every once in awhile the subs cut out. a I set the gain on the amp with a dmm, I have no clue on what the problem is. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5271 Registered: Dec-05
| Posted on Tuesday, April 08, 2008 - 07:01 pm: |
could you post the DVC config? |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 416 Registered: Sep-07
| Posted on Tuesday, April 08, 2008 - 08:27 pm: |
D2s probly. if they're D4s then you got a problem. Is the wiring all sured up? |
Post Number: 54 Registered: Jan-08
| Posted on Wednesday, April 09, 2008 - 04:59 pm: |
yea they are D2's.... I have a wire, on each sub, going from positive to negative. and then I spliced the positives from each sub and the negatives to run to the amp. |
Post Number: 55 Registered: Jan-08
| Posted on Wednesday, April 09, 2008 - 05:01 pm: |
which should give me a 2ohm load, correct? |
Post Number: 56 Registered: Jan-08
| Posted on Wednesday, April 09, 2008 - 05:05 pm: |
ill pull them out tonight when I get out of school just to make sure |
Post Number: 5273 Registered: Dec-05
| Posted on Wednesday, April 09, 2008 - 09:05 pm: |
www.the12volt.com hit woofer configurations |
Post Number: 59 Registered: Jan-08
| Posted on Wednesday, April 09, 2008 - 09:23 pm: |
that's exactly where I went to get it |
