Thread: About my system |
New member Username: Getone06
Post Number: 3 Registered: Apr-08
| Posted on Monday, April 07, 2008 - 04:26 pm: |
right now i have my JL Audio 12W6 and a 16-mc500d memphis i know its a good amp and the sub too but i don;t know if i have it hooked up right and its not hitting like it should don't know if its the amp or speaker |
Gold Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 1578 Registered: Oct-04
| Posted on Wednesday, April 09, 2008 - 04:20 pm: |
Thats only a 500 watt amp. Thats about 1/2 power to those subs. Are the subs dual 4 ohm? Cause that amp is rated at 2 ohms. So if you have the subs wired to 4 ohms then your only getting 1/4 power to the subs. |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 730 Registered: Aug-07
| Posted on Wednesday, April 09, 2008 - 06:28 pm: |
500rms is all he needs. |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1405 Registered: May-07
| Posted on Wednesday, April 09, 2008 - 07:40 pm: |
How do you have the sub wired, and whats your box? |
Tulsa,
Ok
Usa
Post Number: 1581 Registered: Oct-04
| Posted on Thursday, April 10, 2008 - 12:23 pm: |
im sorry, i always think of subs in pairs.... |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 423 Registered: Sep-07
| Posted on Thursday, April 10, 2008 - 02:02 pm: |
Is the box sealed or ported? And specs? Did you set the gain properly? You have a car or SUV? |
