Thread: Some ?'s about new AQ amp |
Bronze Member Username: Diehlerman
Post Number: 47 Registered: Jan-08
| Posted on Monday, April 07, 2008 - 03:06 pm: |
just got my new AQ1200d amp in the mail, I pulled it out of the box and noticed it had 4 speaker inputs (2 neg and 2 pos.) how would I hook up my 2 4ohm DVC subs to get the 1 ohm power? |
Silver Member Username: Imalik
SD2.5......ED9.1=Boom,
New Jersey
Lord Protect...
Post Number: 581 Registered: May-06
| Posted on Monday, April 07, 2008 - 03:53 pm: |
Here You go
Gold Member Username: Big_edge_head
Milwaukee,
Wisconsin
MY SUBS GET ...
Post Number: 1877 Registered: Mar-07
| Posted on Monday, April 07, 2008 - 03:59 pm: |
All you have to do is use 2 of the four terminals on the amp btw |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7274 Registered: Jul-06
| Posted on Monday, April 07, 2008 - 07:27 pm: |
Both + and both - are connected together in parallel inside the amp. Using one set or both makes absolutely NO difference as long as your speakers are wired to the correct impedance. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5266 Registered: Dec-05
| Posted on Monday, April 07, 2008 - 08:24 pm: |
that's called monoblock |
Milwaukee,
Wisconsin
MY SUBS GET ...
Post Number: 1879 Registered: Mar-07
| Posted on Monday, April 07, 2008 - 10:52 pm: |
Dual monoblock* |
Post Number: 50 Registered: Jan-08
| Posted on Tuesday, April 08, 2008 - 01:40 am: |
ok...just making sure they have some goofy a s s diagrams in the manual. |
Northwest PA
Post Number: 7281 Registered: Jul-06
| Posted on Tuesday, April 08, 2008 - 03:08 am: |
" Dual monoblock* " NO, that would be two mono amps in one case, which this is not. |
Post Number: 5270 Registered: Dec-05
| Posted on Tuesday, April 08, 2008 - 06:59 pm: |
exactly. |
Bronze Member Username: Corbin01gti
Post Number: 17 Registered: Apr-08
| Posted on Saturday, April 12, 2008 - 06:01 pm: |
how long did it take to get your amp. i just ordered the 2200 on friday |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 885 Registered: Jun-06
| Posted on Saturday, April 12, 2008 - 06:48 pm: |
I have a question about my AQ1200! I got everything wired, and the system is working, but it is not being powered all the way. It's like the resistance is wrong or something. Ive tried wiring it in different ways but its still the same. Do I have to have both positive and negative terminals going to my subs? |
Post Number: 61 Registered: Jan-08
| Posted on Saturday, April 12, 2008 - 08:38 pm: |
took 4 days to get it |
Bronze Member Username: Jnralp00
Post Number: 26 Registered: Nov-06
| Posted on Monday, April 14, 2008 - 12:01 am: |
Nice choice of amps... I'm running two of the AQ2200's |
