Home > Message Board > Car Audio > Speakers > Car speaker only starts to play after...
Author Thread: Car speaker only starts to play after high volumes
Username: Caraudio
Toronto, Ontario
Post Number: 807
im listening to music in the car and first i thought the Pos Neg were a problem so I swapped them (from the deck) I was not going to take the door apart again trying that for 45min would of been a huge waiste of time. Now it sounds like it turns on after i turn the volume up to about 30/40 then it stays on after a while it may cut off again.
AnyIdeas?
Relevant Product Info
Username: Prozack52
Cincinnati, 2-D615D4 Dia...
Post Number: 338
what you mean "it sounds like they turn on after 30/40" they either turn on or they dont
Username: Jayhunter
Post Number: 7
Did you check if the speaker is blown yet? Maybe the high volume gets in moving and the low volume isn't enuogh to move it. Also, are they stock?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Speakers > Car speaker only starts to play after... [ « Previous ] [ Next » ]
