Thread: Box question |
| Posted on Saturday, June 05, 2004 - 12:07 am: |
Sence the other forums are still down, id thought i would ask it here.. I have a Punch HE2 sub, 400rms that im looking to get a box for. I have one already, thats 14-13-13, do you think that would do good for this sub? or should i get a biger one? Thanks. |
Silver Member Username: Bdb_86
Bemidji,
MN
Usa
Post Number: 152 Registered: Dec-03
| Posted on Saturday, June 05, 2004 - 12:28 am: |
what size is the speaker 8",10",12"...? |
daven22 Unregistered guest |
| Posted on Saturday, June 05, 2004 - 12:31 am: |
sorry, 12" |
Bemidji,
MN
Usa
Post Number: 153 Registered: Dec-03
| Posted on Saturday, June 05, 2004 - 12:43 am: |
i just looked up the speks and well you can go larger or even smaller so the one you have should be just fine i think that should be all that you need you did mean 14"-13"-13" right not like cm or any thing
| Posted on Saturday, June 05, 2004 - 12:51 am: |
yea, inches, so i should be fine? its a bit smaller than that, becuase the top of it is angled down a big if you know what i mean, but you think ill be good? |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 199 Registered: Apr-04
| Posted on Saturday, June 05, 2004 - 07:15 pm: |
Yeah, you should be good. By the way nice sub i have one exactly like it myself. |
Daven22 Unregistered guest |
| Posted on Sunday, June 06, 2004 - 10:01 am: |
Thanks, My amp is comming in wensday, cant wait to test it out! |
Silver Member Username: Its_bacon12
Post Number: 646 Registered: Dec-03
| Posted on Sunday, June 06, 2004 - 11:25 am: |
im not a fan of RF subs at all elemental designs on the other hand... |
