Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Help With Old Amp! Rodek :-)...
Author Thread: Help With Old Amp! Rodek :-)
Username: Slaughter
Toronto, On
Hey Everyone :P I need help :-(
I just obtained a Rodek RA250E Amp and I don't know anything about it. I was told that the Yellow Wire is the Ground, and Black is power. The Blue for Remote. And The 4 remaining wires are for the speakers. I want to confirm this because the Yellow/Black switch is different to me. If anyone has any other info on this amp I'd appreciate it. Thanks.
Username: Germanguy
Post Number: 36
I donīt know about the wiring, but the Rodek amps are ditributed by ACR in europe. they range upper medium class and are considered as best entry level amps, since they put out clean power at a low price. SQ should be quit satisfying for middle class
normaly it is yellow as power and black as ground i dont think that any company no matter were its from is dumb enough to make there wiring the other way around so try this, first get a 12v battery charger twist the blue and yellow wires to gether and connect them to the red on the battery charcher and then connect the black to black for about 3 seconds and see if the amp turns on if it dont then try switching the black with the yellow and repeat the 3 seconds thing
Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Help With Old Amp! Rodek :-)... [ « Previous ] [ Next » ]
