Thread: PPI amps |
Bronze Member Username: Msand951
Riverside,
Ca
Usa
Post Number: 59 Registered: Mar-07
| Posted on Friday, April 04, 2008 - 01:37 am: |
are PPI amps good or should i stay away from them . is the rms watts true. |
Platinum Member Username: Nd4spd18
Northwest PA
Post Number: 7231 Registered: Jul-06
| Posted on Friday, April 04, 2008 - 02:31 am: |
Old PPI amps = some of the best ever made IMO New ones = still good but not like the old ones. |
Riverside,
Ca
Usa
Post Number: 60 Registered: Mar-07
| Posted on Friday, April 04, 2008 - 10:19 am: |
is $250 for a 2000 rms PPI amp good. im trying to find out what model it is. he says it a competition amp. |
Platinum Member Username: Th3pwn3r
Post Number:...
Post Number: 7758 Registered: Jul-06
| Posted on Friday, April 04, 2008 - 01:27 pm: |
Assuming it's in decent condition and rated properly any 2,000 watt RMS amplifier is a steal for $250. |
Riverside,
Ca
Usa
Post Number: 64 Registered: Mar-07
| Posted on Sunday, April 06, 2008 - 12:54 pm: |
i think its a good deal he will take 200 works fine. its is an old one cause it has two 4 gauge power inputs instead of 1 0gauge. http://www.precisionpower.com/amps/pcx2400.asp but according to the web site it only does 1600 bridged @ 2ohms. I also have a hifonics 2006d 2000rms but its more like 1500 rms at 1 ohm. which is better. which one should i stick with. |
Northwest PA
Post Number: 7254 Registered: Jul-06
| Posted on Sunday, April 06, 2008 - 04:09 pm: |
That is one of the newer ones. But still, PPI > Hifonics Also, that amp says it does 800x2 at 2 ohms, which probably means that 1600w bridged is at 4 ohms.
Riverside,
Ca
Usa
Post Number: 66 Registered: Mar-07
| Posted on Monday, April 07, 2008 - 05:16 pm: |
i has two power and grounds. for 4 gauge i think .so should i try to use 0 gauge. i was thinking of running 0 gauge from battery to a split it into two 4gauge. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5269 Registered: Dec-05
| Posted on Monday, April 07, 2008 - 08:48 pm: |
PPI= older=better |
