Home > Message Board > Car Audio > Accessories > Battery question
Author Thread: Battery question
Username: Msand951
Riverside, Ca
Usa
Post Number: 58
my budget is kind of tight. but need to upgrade my battery are any of these battery better than stock for audio purposes. if i were to put bigger stronger battery can it damage my car. because i was thinking of upgrading my truck and putting the stock battery on my van. i think the van could use my truck battery there both dodges. http://inlandempire.craigslist.org/rvs/626520417.html
Relevant Product Info
Username: Nd4spd18
Northwest PA
Post Number: 7230
If you don't have an HO alternator a battey alone won't prevent voltage drop
Username: Th3pwn3r
Post Number:...
Post Number: 7751
The advantage of changing your battery would be that it will last longer more than likely as it would probably be deep cycle.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Accessories > Battery question [ « Previous ] [ Next » ]
