Thread: Good deals on amps |
New member Username: 88retta
Farmtown,
Oh
Post Number: 7 Registered: May-04
| Posted on Friday, June 04, 2004 - 12:51 am: |
Is 20 $ a good deal for a used jensen amp, it is 250 watts, 2 ohm stable. And is 100 $ good for a brandnew, never used pyramid 1000 watt 2 channel amp ? I'm pretty much only buying stuff if it is cheap, and i'm not too sure if this stuff is cheap prices, or cheap product. Could somebody give me some info on that |
Bronze Member Username: Davids2004
Houston,
TX
Post Number: 17 Registered: Jun-04
| Posted on Friday, June 04, 2004 - 01:01 am: |
I would say the jensen is a decent price but in no way is it top of the line but it will work for what you need to do. What you need to look at on that jensen amp is the rms wattage and not the max wattage. Now the legacy amp stay far far away from. Save another 50-100 and get a good amp. What are you gonna be pushing with these amps and we could recommend you an amp. |
| Posted on Friday, June 04, 2004 - 01:02 am: |
Man save some money and buy something worth having those amps are just plain crap. |
