Thread: Need a good amp |
New member Username: Squals368
Pittsburgh,
PA
Post Number: 2 Registered: Jun-04
| Posted on Friday, June 04, 2004 - 12:01 am: |
I have a 12 inch alpine type R sub 1,000 watt peak, 300 watt rms. Any suggestions on a good amp to make this hit nice and hard? |
Bronze Member Username: Davids2004
Houston,
TX
Post Number: 19 Registered: Jun-04
| Posted on Friday, June 04, 2004 - 01:02 am: |
Ported or sealed box. |
| Posted on Friday, June 04, 2004 - 01:06 am: |
A kicker KX350.2 bridged will do the job for you. |
Houston,
TX
Post Number: 22 Registered: Jun-04
| Posted on Friday, June 04, 2004 - 01:53 am: |
anonymous you sure dont seem to know too much about car audio. How are you gonna recommend an amp if you dont know what kind of box he is running. If hes running ported I bet that amp doesnt have a SS filter on it which you will need. Some of your responses have been off the wall sometimes. |
Pittsburgh,
PA
Post Number: 3 Registered: Jun-04
| Posted on Friday, June 04, 2004 - 02:05 am: |
the box i have is a box and sub combo that i got from alpine.com. 12" Compound Reflex Subwoofer Box 2ohm (4ohm + 4ohm) |
Silver Member Username: Jonathan_f
GA
Post Number: 260 Registered: May-04
| Posted on Friday, June 04, 2004 - 02:14 am: |
"Some of your responses have been off the wall sometimes." Just thought that was funny, since you're referring to someone thats listed anonymous. Mike, is the sub DVC 4 ohm or DVC 2 ohm? If it is DVC 4 ohm, a JBL 300.1 would be good. If it's DVC 2 ohm, get a 2 channel with 300RMS bridged. Doesn't really matter if the amp has a subsonic filter if the box is ported, you can get an F-Mods subsonic filter and that'll solve that problem. |
GA
Post Number: 261 Registered: May-04
| Posted on Friday, June 04, 2004 - 02:17 am: |
Sorry, you beat me to the post. A JBL 300.1 should be good, not sure what that box is tuned to, but you can look on the website or instructions and look for an F-mods subsonic filter to match it and it will solve that problem. |
GA
Post Number: 262 Registered: May-04
| Posted on Friday, June 04, 2004 - 02:27 am: |
http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3 20 hz high pass should work for that box. |
