Home > Message Board > Car Audio > Speakers > Archive through May 21, 2008 > Comparison help
Author Thread: Comparison help
Username: Matrixwolves
Wichita, Ks
Post Number: 8
I have a set of jl XR650-CSi. How does the cdt HD-62 compare to them? Is the rms on the hd-62 and the cl-62 really more than double the jl'S?
I've blown my coax on the jl set and guessing i need a higher rms rated speaker but i still want some sq. Any help is appreciated.
Username: Drant19
DUB-C, TX
Post Number: 620
im getting the HD-62, and have been told they can take 250rms as long as its clean power.
Diamond Member
Los Angeles, CA
Post Number: 19974
hd 62 sounds way better. i've used them both and its no comparison.
Username: Exige
Cincinnati
Post Number: 216
correction lol....that crossover that you and i discussed can take 250w. 200w will be plenty for the set as a whole though.
deandre, if you're interested in CDT let me know, i'd be happy to assist you.
Username: Drant19
DUB-C, TX
Post Number: 651
whoops lol my bad
Wichita, Ks
Post Number: 9
Yes I'm very interested in CDT. Basically I'm looking for quality sound that I can put more power to versus what i had before and not worry about them blowing. Also I will need and amp to power them, but don't want to spend alot on it.
Username: Exige
Cincinnati
Post Number: 219
Deandre, check your PM's...just sent you one.
Home > Message Board > Car Audio > Speakers > Archive through May 21, 2008 > Comparison help [ « Previous ] [ Next » ]
